Welcome to ACC Ideas! Please note not all ideas receive a response and top voted ideas will be considered for future development. Click HERE for more information on the feedback process. Thank you for your ideas!
in the Submittals section under "Build", when one tries to create an item, and as they scroll down that box, filling in the required information, one hits a bump where that creator can't select a package or a review template unless they're a Submittal Manager (The two boxes don't appear). Any project member whether a general contractor, subcontractor, supplier or any other project member with access to "Build" should have the option to select a package and template. without the need to add them or their "Roles" (The creator) to a growing list of submittal Managers. add to the problem, if we decide to add 10 or 20 Creators with the role of a Submittal Manager to allow them to select a package or a workflow template. the next option in the Item creation box will be a long list of members, all of whom are Submittal Managers, and that creator needs to pick one!
Adding every creator to the SM's list will undermine the regulatory nature of a Submittal Manager role, especially the one selected by the GC or the EOR to manage the submittals traffic! Keep in mind ACC learning videos suggest we have one or two submittal managers at most. The solution is that there should be an option under settings that allows any member with access to "Build" to create Submittals without them being listed as a submittal manager
