Currently, when you click on a takeoff object in ACC, it only shows the primary output (e.g., area, length, etc.). However, it doesn’t display any of the additional outputs that are part of that condition.
You can view the summed additional outputs in the condition details panel, but that doesn’t help when you want to see the values for a specific object. I know using locations can be a workaround to break things down further, but that introduces its own challenges.
It would be really helpful if clicking on a takeoff object could show all associated output values, not just the primary one. This would give much better visibility into the data behind each object and make quantity verification more efficient.
Anyone else run into this or found a better solution?
