I understand the desire to conserve local file space, which is one reason the desktop connector has moved to select only 80 projects to keep locally. The issue our firm will see with this switch is that we have employees who work on over 100 projects within a short period. Having to select which projects to sync locally can cause confusion and result in the BIM Managers having to remind and troubleshoot visibility problems. If there was an option for optimizing storage, which would enable the project selection or an override to select all projects, I think this would help many firms that will be experiencing the same problem we will.
