Welcome to ACC Ideas! Please note not all ideas receive a response and top voted ideas will be considered for future development. Click HERE for more information on the feedback process. Thank you for your ideas!
Description field on OCR data capture
When processing PDFs with OCR as part of the Titlesheet Templates, the Description Field is not available.
This is forcing us to finish the process by manually adding a description value to each and every single file that goes into our named enforced folders.
This documents are later sent in Transmittals.
Our company uses ISO 19650 complaint drawing names, therefore there are no words describing the contents of each doc, making it paramount to use the Description Field, which is the only that is a constant during the flux of information.
Also, it would be ideal to have the Titlesheet Templates as part of the project template, because we are building them manually upon creation of projects wasting our time.
1 Comment
Chris_D_UK
This is desperately needed. Hundreds of hours lost each month doing this manually.
