Welcome to ACC Ideas! View the ACC Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Cost Management Markups on Proposed Column
It is my understanding that the "Proposed" column in the Change Order module is related to downstream suppliers (subcontractors).  So not understanding why financial markups auto calculate on that column. Markups don't calculate on the "Committed" column which makes so why does it on the "Proposed" column.  "Estimated", "Submitted" and "Approved" are upstream columns so auto calculating on those columns makes sense.
Seems like another setting that could be set (on or off) in the settings part of the system so companies can set a standard depending on how they use ACC.
1 Comment
ian_turner
Hello
Because our customer feedback was if the Change Order is upstream (obviously committed is only downstream) and you will use the proposed value to send to the customer, it is useful to see what that number will be including your markups before creating the COR
If you'd like to see just the quoted numbers without markups you can see them in the RFQ view
