Welcome to ACC Ideas! View the ACC Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Conditional Dropdowns for Precision Data Entry in Forms
Problem Statement:
In the current Autodesk Build Forms, we plan to use them to submit Work Inspection Requests (WIRs). However, to ensure standardized and precise data collection, we need the ability to use dropdown fields with conditional logic. At present, Forms don't support dynamic dropdowns where the second dropdown auto-populates based on the selection in the first.
Proposed Solution:
Introduce multi-level conditional dropdown fields in Autodesk Build Forms. This enhancement would allow form creators to define a parent-child relationship between dropdowns, where the selection in one field determines the options available in the next.
Example Use Case:
  • Dropdown 1 (Category): Concrete Works, Earthworks, Structural Steel, etc.
  • Dropdown 2 (Sub-category):
    • If "Concrete Works" is selected → Show "Formwork", "Rebar", "Pouring", etc.
    • If "Earthworks" is selected → Show "Excavation", "Backfilling", "Compaction", etc.
Benefits:
  • Reduces manual entry and error in WIRs and similar forms.
  • Ensures consistent data structure across inspections.
  • Speeds up form completion and review.
  • Enhances data analytics by structuring input categories.
1 Comment
Mike.FORM
I think you are in the wrong forum for the wrong product.
This is a forum for suggesting Autodesk Revit features.
Revit does not have forms and also I would not suggest to do this type of thing in Revit as there are many other programs that could do this.
Excel can accomplish exactly what you are requesting using data validation lists.
