Column Width Adjustment Stays while Utilizing Sort Function
I sort through a lot of data on ACC, especially in the Forms and Files. Frequently I need to change the width of the description column so I can see what I'm working with. Utilizing the drag and drop feature works, but it is incredibly easy to accidentally select the column, causing the data to be resorted.. and the column width to be reset! I do this multiple times a day every day. Please enable a feature to where once the column widths are adjusted, they stay, even when re-sorting the data via different columns and parameters. This would save me hundreds of hours every year, and is already in place in other data management software such as Excel, so maybe there is already existing code for this type of feature tweak. Thank you!
View short, easy-to-follow videos about how to use Autodesk's construction products.
