The Autodesk Desktop Connector virtual file path name for Autodesk Docs is VERY long and contributes to maximum file path name violations. It would be helpful change the top level ACC Docs folder name from "Project Files" to just "Docs".
Our company hub name is only 4 characters and my personal company user id is only 5 characters which is shorter than most, but by the time "Project Files" is reached in the file path name over 50 characters have been used. Not to mention that spaces count as 3 characters for maximum file path. Example Autodesk Docs virtual file path below:
C:\Users\userid\DC\ACCDocs\HubName\Project_Name\Project Files
It would be a step in the right direction to reduce the top level folder name from 13 (technically 15 with the space) characters to just 4 characters. Every little bit helps!
