Bridge link removal
Bridge link removal
Mistakes will made when setting up Bridge between ACC Projects.
After being created Bridges can only be hidden i timelines and Bridge overview, not permanently removed.
But hidden bridges can not be filtered out neither generally nor specifically by project the Bridge comes from. They can only be hidden by filter "external" status and that hides all bridges, regardless of active/hidden status.
A Bridge should be possible to remove completely in the case it turned out to be unhelpful in retrospect. Or at the very least to be filtered put by Project or disabled/invisible status so users will not be bothered by irrelevant information.
Also external teams from bridges are automatically sorted above internal making it even more distracting being placed at the top in timelines. Order should be better prioritized or atleast customizable.
4 Comments
Ramolla.Marco
Status changed to: Accepted
paul.eterovichY6MNN
Has this been implemented? How do you completely delete a bridge?
omb_tsargent
I tested bridging with a full folder with 20+ files in it... my poor Design Collaboration tab. :sad_but_relieved_face:
paul.eterovichY6MNN
what happened?
View short, easy-to-follow videos about how to use Autodesk's construction products.
