Upon document upload, automate the generation of a brief description based on file content or metadata.
Users can quickly identify uploaded documents without manual input through filtering metadata by using the Attributes from the Search Function, saving time and effort.
Example: My Native Revit Sheet is named "FRA01_ENER_XX_01_SP_AR_0001-GroundFloorElectrical"
when uploading to ACC Docs using Enforced Naming Convention, the Sheet should be split according to the enforced Attributes FRA01, ENER, XX, 01, SP, AR, 0001, however the "GroundFloorElectrical" is automatically eliminated from appearing in the Description Attribute and then needs to be manually added to the Description.
In use cases where we have hundreds of plans, manually adding ACC descriptions to all of these plans is very resource consuming.
Using the search function provided by ACC is also not ideal, as if I would like to identify all floor plans containing the string "Floor", there would be no results pinged back, unless this value is written in the Description field.
The benefit of automating such function is to reduce manual data entry and to improve document organisation.
Implementing this feature would significantly enhance user experience with ACC Docs.
