Auto-Publish & Markup Toggles
A toggle to auto-publish markups like Photos in BUILD needs to be added.
While the photos added by users will auto-upload to the "Photos" tab, if the user doesn't hit "Publish" for each and every photo, they are not linked back to plans.  This makes the entire process significantly less efficient.
Worse still if you do not capture this and the employee leaves, there is no way to recover that markup location as even Administrators can't publish "private" markups.  (Which, be definition are still property of the company, so should be relabeled as "User" markups. )  So a toggle for making User Markups Public needs to be available to project Admins.
View short, easy-to-follow videos about how to use Autodesk's construction products.
