Welcome to ACC Ideas! Please note not all ideas receive a response and top voted ideas will be considered for future development. Click HERE for more information on the feedback process. Thank you for your ideas!
Allow "Descriptions" to be added to folders
It would be great it "Descriptions" could be added to folders. This way we could show the intent of our folder structure to less familiar / external project team members .
8 Comments
lance.borst
Hi!,
I'm trying to understand the request a little deeper. Would you suggest using the same "Description" column that can be used to describe the folder contents, or do you see another area/form to place a folder description? For example, if you were to hover over a folder should it show a description?
rwheelerXEXYH
Hi Lance,
Yes - the intent is that the Description column in Docs would be usable for folders as well.
Thanks!
Charlv_Beca
We also would want these Description fields ( once enabled inside ACC) to be visible in Windows Explorer - Similar to how the 'Status' field is mapped from ACC to Windows Explorer.
dave_middle_VQRN7N5HJ2DC
Community Visitor
This would be a great asset, within the ACC/BIM360 Environment we are restricted to the character counts. Therefore, using the folder name as a descriptor (i.e. A - Architectural), the description could be used to identify the need of the folder (for instance, Folder A, would have the description Architectural), greatly reducing the character count.
jeamy.baena
If you need to generate folders with shorter names, the "Description" attribute will help a lot in this task, since it will contain more detailed information about its content. It will very helpfull when you hover over a folder should it show this description.
This is a must and a basic usability feature that has a lot of impact on the speed with which information is examined. I also understand that the API already supports this functionality.
This request can be found here in another wish list and was registered years ago. The truth is that it is a simple improvement and should not wait so many years or so many votes.
rwheelerXEXYH
It looks like this was just implemented in the November ACC updates (browser descriptions only). Thanks Autodesk! 🙂
jeamy.baena
Greetings,
This feature was already included in november ACC update. (At last!). Please see the help: https://help.autodesk.com/view/DOCS/ENU/?guid=Docs_Whats_New_November_24
jonminick
Thanks @rwheelerXEXYH and @jeamy.baena for the timely updates. We are actively working to catch up on existing impactful Idea posts with updates.
As mentioned, this was part of the November 2024 release and functionality is currently live in product.
