Welcome to ACC Ideas! Please note not all ideas receive a response and top voted ideas will be considered for future development. Click HERE for more information on the feedback process. Thank you for your ideas!
Currently, the Schedule tool in Autodesk Build allows users to set project workdays (e.g., Monday–Friday or Monday–Saturday) from within individual project settings. However, there is no option to define default workdays in a project template.
For companies managing a large number of projects, this becomes time-consuming and repetitive, as we must manually adjust the workdays for every new project created from the same template.
Proposed Improvement:
Add an option within Project Template Settings (under the Schedule configuration) to define default working days — for example, Monday–Saturday. When a new project is created from that template, the defined workdays should automatically apply to the project schedule.
Benefits:
Example Use Case:
Our organization manages 30+ active construction projects, all following a Monday–Saturday schedule. Having this configuration built into templates would streamline project setup and improve accuracy across teams.
