Welcome to ACC Ideas! View the ACC Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Show only
Search instead for
All cost and build settings that a project administrator is able to set with in a project should be available in the project template. this would save time for majority of project creation and setup.
All Cost Settings except project specific users & permissions are able to set up in a project template today
Additionally Custom Attributes, Custom Columns, Saved Views and Document templates can all be managed in the account library which allows you to push out to all in flight projects and existing project templates
@ian_turner Understood. I would like what has been done on the cost side permission and settings to the what the build side implements. Only issue with the saved views is that I would like to pick and choose which views are saved, currently its all view or no views. might want to save 5 out of the 10 views
If you set up a test/sample project which you use to be the master for setting up custom attributes, custom columns and saved views, then in the library pull in those settings, you can push out wherever you like, other projects, existing templates.
So if you only want 5 views, only keep 5 views in that project?
