ACC Parameter Service - Select all, edit all, download and share capability
Welcome to ACC Ideas! View the ACC Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Show only
Search instead for
In the ACC Parameter Service. There needs funtionality to Select all, edit all, download txt and share capability for the parameters or a collection of parameters.
I agree, there needs to be a select all when doing anything with the parameters.
But the rest of what you mentioned basically does already exist. See below screenshot for the export option.
In order to select multiple items, you can select either the "Labeling View" or the "Edit View". When you say "download txt", I assume you mean to download the parameters to a shared parameter .txt type file? You can already do that, see screenshot below. When you have your selection made, you can click the vertical ellipsis and choose Export. I'm not sure where it goes after that. Never used the feature and right now it doesn't seem to be working. I have put in a support ticket.
Share capability of parameters I believe is on their roadmap already. But interestingly enough, right now any firm/hub that I am a project member of at least one project in ACC with, I have access to their shared parameter list if they have set up their Parameter Service which isn't necessarily bad. If I need a new parameter, why not use one someone else that we work with maybe already has... This could get to the world of "one shared parameter list for all" type stuff... but I digress.
In lieu of the Select All option for the meantime, you can do a shift select to select an entire list of items.... click the top item, scroll to your bottom item in the list, press shift and click on that bottom item.
So really the only thing that isn't already there is the single button to Select All and more control over sharing shared parameters, but really if you want to share shared parameters, that seems to already be there, but just perhaps no way of NOT sharing shared parameters.
