ACC Model Coordination - Issue visibility created from Navisworks Coordination plug-in
ACC Model Coordination module currently provides a great clash view of issues created when they are created directly from the ACC Model Coordination. However, if you create issues using the Coordination add-in in Navisworks, the view in Model Coordination now shows every model component vs. just the clash (red and green) and all other objects ghosted. It is hard to narrow in on the actual clash itself without a lot of manual work. It would be beneficial to have the same clash view whether the issue is created directly in ACC Model Coordination or via the Coordination add-in.
View short, easy-to-follow videos about how to use Autodesk's construction products.
