When creating document templates in ACC Cost, you can only access these variables related to taxes:
Imagine 21% tax has to be paid on an item that costs $1.000,00:
- Amount = $1.000,00 * 21% = $210
- Name = "21% tax"
- Rate = 21
- Type = ?
In Belgium, we also need to know the "Base amount" on which a tax was calculated.
You can manually calculate the "Base amount":
Base amount = Amount / (Rate/100)
For example:
1.000,00 = 210 / (21/100)
The problem is that we sometimes need to use a 0% tax rate.
In that case, the Base amount can't be calculated, because it would require dividing by zero.
