One of the good features of ACC/Docs is that you can create a new project using a project template that contains multiple folders, files, members, companies, roles and settings. This saves a lot of time setting up new projects.
However, it is very easy to accidently forget to select a template when creating a project. In this situation you either have to upload the contents of a template structure manually from an alternative source (and the only way to do this is via the clunky ADC) or manually via the web interface one folder at a time, which is very time consuming in our case, or archive the project in ACC (remember you can't delete projects in ACC, even if you are an account admin) and then recreate the project, but this time remembering to select the project template when doing so. It would be very useful if a project template could be assigned and populate the newly created blank project after that blank project has been created.
