ACC General Discussion Forum
Share your knowledge, ask questions and explore popular discussions about everything ACC
Xref attached with Autodesk docs points to previous saved C:\ of colleagues and requires relink after opening
2 REPLIES 2
hugomABZ3T
111 Views, 2 Replies
Good afternoon.
We have recently moved onto the autodesk construction cloud for productivity, however, each time a colleague opened and saved a drawing the xref's remembers their autodesk desktop connector file path and I have to go and relink all the xrefs.
Is there a way to link it to the actual file in the cloud so that it will not remember anyone's C: path, or perhaps an alternative way of doing it?
Looking forward to your response.
Kind regards
Hugo
Labels (2)
2 REPLIES 2
cadffm
in reply to: hugomABZ3T
from now, use relative path type for xrefs.
Sebastian
cadffm
and life with the negative trouble with relative pathes then.
(If you move a mainfile to another folder level, the xref will not found)
Sebastian
View short, easy-to-follow videos about how to use Autodesk's construction products.
