ACC General Discussion Forum
Share your knowledge, ask questions and explore popular discussions about everything ACC
Viewing Point Clouds in ACC
2 REPLIES 2
sales7NF7D
144 Views, 2 Replies
Is it possible to view point clouds via ACC?
Second to that is it possible to send a link to a client so they can view the point cloud and the design model?
Labels (1)
2 REPLIES 2
Hi @sales7NF7D
Autodesk Construction Cloud (ACC) does not natively support viewing point cloud data directly within its platform unless the data is converted to a compatible format like a ReCap file. However, there are workflows available to integrate and share point cloud visualizations effectively.
While ACC lacks built-in rendering tools for point clouds, you can use tools like ReCap Pro or Navisworks to process and visualize the data. For combining point clouds with a design model, Revit or Navisworks works well.
Sharing Point Clouds with Clients
You have two primary options for sharing with clients:
  1. Grant Access via Autodesk Docs in ACC: Upload point cloud files to ACC and grant project access. While point clouds formatted as ReCap files can be viewed, non-ReCap files must be downloaded and opened in a compatible viewer.
  2. Share a Link via Autodesk Docs in ACC: Place the point cloud files in a folder and share a downloadable link. Clients won't preview the files this way but can download and open them using appropriate software.
Suggested Workflow
  1. Use ReCap to preprocess and export a smaller, optimized point cloud dataset.
  2. Combine point clouds and design models in Navisworks, then export a .nwd file. Upload it to ACC for sharing or viewing.
Let me know if you need further guidance on tools or workflows! :smiling_face_with_smiling_eyes:
JORDAN BULLOCK
Autodesk Certified Instructor
Technical Specialist & Implementation Consultant
John_DeLeeuw
in reply to: sales7NF7D
What about ACC EU server? No RCS file seems to be viewable yet?
John de Leeuw
Senior Consultant
Community Ambassador - Twitter - LinkedIn
View short, easy-to-follow videos about how to use Autodesk's construction products.
