Is it possible to view point clouds via ACC?
Second to that is it possible to send a link to a client so they can view the point cloud and the design model?
Solved by jordan_bullock1. Go to Solution.
Hi @sales7NF7D
Autodesk Construction Cloud (ACC) does not natively support viewing point cloud data directly within its platform unless the data is converted to a compatible format like a ReCap file. However, there are workflows available to integrate and share point cloud visualizations effectively.
Viewing Point Clouds in ACC
While ACC lacks built-in rendering tools for point clouds, you can use tools like ReCap Pro or Navisworks to process and visualize the data. For combining point clouds with a design model, Revit or Navisworks works well.
Sharing Point Clouds with Clients
You have two primary options for sharing with clients:
Suggested Workflow
Let me know if you need further guidance on tools or workflows! ![]()
JORDAN BULLOCK
Autodesk Certified Instructor
Technical Specialist & Implementation Consultant
