Sync of Materials in Autodesk Docs
g_michelsSWECN
Message 1 of 1
g_michelsSWECN
Community Visitor
Community Visitor
I'm migrating from Google Drive to Autodesk Docs to keep my projects.
I usually had my .rvt files in google drive, organized by projects, and in the folders of every project I used to have subfolders with the exported PDFs.
Using the publish config. I can select the sheets I want to see and then I dont need to export to PDF anymore. (this is being also useful to create issues stright from the construction site).
The thing is that the 3D perspectives and isometrics I'm inserting on my sheets loose the sync with my material folder and library, even saving the library file (.adsklib) and textures (.jpg) on a folder inside the project in Autodesk Docs.
I really don't want to use pdfs again, because it would be a stepback in the workflow I'm trying to implement.
Am I doing somethig wrong or it's an Autodesk Docs limitation? Does anyone else also passed throught the same issue?
Thanks!
Replies (0)
