ACC General Discussion Forum
Share your knowledge, ask questions and explore popular discussions about everything ACC
Suggesting Schedule Updates
1 REPLY 1
jagramonteAK8CF
103 Views, 1 Reply
I'm trying to use the Impact Column but when I click the button to add Root cause the emergent window just dissapear if I move the cursor outside window. (Image 1 y 2)
While, if I select to suggetions panel and I change the suggestion's status manually the section let me to add a note (Image 3)
Labels (2)
1 REPLY 1
Hi user,
This is not an intended behavior within the schedule tool. I just walk through the workflow that you prescribed in your question. I recommend navigating to the? in the upper right-hand corner and open a support ticket.
View short, easy-to-follow videos about how to use Autodesk's construction products.
