SSM for Web - Change Drawing/Layout for a Sheet
Cadguru42
Advisor Advisor
Cadguru42
Is there a way to reassociate a different layout to a sheet for SSM for the Web like the "old" SSM can?
We have a C3D project in ACC where we had to create sheets before the alignment was even finalized (I know, we told them this was bad). Now that the alignment has been updated, I've recreated new view frames and want to create drawings for them. Since we populated the sheet data in SSM-W previously, we'd like to change what layout a sheet in the SSM-W is pointing to, but it seems to be a read-only property of a sheet as shown below.
Is there a way to reassociate a SSM-W sheet with a different layout? If not, so long as the layout name is the same and the drawing name the same can the original file be overwritten and SSM-W still read the new drawing/layout?
C3D 2024-2026
Windows 11
32GB RAM
Cadguru42
It looks like Autodesk has not provided a way to reassociate an existing sheet in a SSM-W, so I had to redo the entire sheet list and fill out the data again.
This is not user friendly and is a huge step backwards. Autodesk really needs to add the ability to reassociate an drawing & layout from an existing sheet.
C3D 2024-2026
Windows 11
32GB RAM
ceethreedee.com
Yep me in the same boat... this is broken... also the sheet views are not working..
See my post of other stuff missing here
https://forums.autodesk.com/t5/acc-general-discussion-forum/sheetset-manager-for-web-2025-missing-fu...
Civil 3D 2025 / Infraworks 2025
Win 10 -DELL Precision Notebook 7680
Want FREE TOOLS! Come get my free productivity tools for civil 3d from the appstore here Ceethreedee tools
Or from my website below!
https://ceethreedee.com/ceethreedee-tools
Cadguru42
Just a follow-up that after 23 months this still is an issue even with the "new and improved" SSM with 2026.1. Even though Autodesk integrated parts of SSM-W into the core SSM, if you reassociate a sheet with a different layout/drawing then the C3D match line label still won't read the sheet number. It can ONLY read the sheet data from the initially created layout that a sheet was created with by the plan production tools. This is an undocumented change and Autodesk doesn't seem to understand what their changes have done.
C3D 2024-2026
Windows 11
32GB RAM
