Renaming .dwg seems only to copy it to the new file name, not allowing a new design to use its original name.
I have a question about the saving and naming of .dwg files. I am a student and new to AutoCAD and I was given a fairly simple assignment to complete which I did well in advance of its due date. In the meantime, my instructor changed some of the requirements for this assignment, including the modelled object itself. Rather than going back to my original design and altering it, I merely started a new design.
Within the class there is a simple rubric for the naming of the files we submit, 'name-assignment.dwg' so I first renamed the original file I had created so I could use the required rubric on my new file. I noticed after I had submitted (what I thought was) my new file I discovered that AutoCAD had not changed the name of my older file, it made a copy with the new name, but my original file was still intact under the required name. It did save my new file as 'rubric.dwg ('my name' 'conflicted copy' 'yyyy-mm-dd').dwg'. Interestingly, the .bak file using the original file name is of my new work, not my older design.
Is this intentional? What is the reasoning behind not being able to rename .dwg files? Or is there something else going on here I should be paying attention to?
