Recording structure defects onto ACC mobile 3d model using a tablet
mattieb
mattieb
I'm just unsure if this is possible or what Autodesk products to use...
My team inspects structures. We usually create a full 3d Revit model of the structure before we go out and record defects. I want to be able to record these defects on an android tablet during the inspection by orbiting & tagging a 3d model. I then want to apply these tags to the revit model to create 2d defect drawings. (Placing defect families which can then be loaded with data in parameters)
My company has a global license with access to all products including Autodesk Construction Cloud.  A solution I thought of was using ACC on site on the tablet, orbiting the 3d Revit model & recording defects as 'issues', but then there is no seamless way to show/ attach this data to the model to show in 2d sheet views. I'm trying to remove a step of re-writing & placing the defect note.
Feels like Autodesk should have a ready made solution to this that we don't know about. If we could get location (xyz) data from this defect tag we could use Dynamo to develop a solution, but its the recording the data on site part that I need advice with.
mattieb
bump, any ideas
