ACC General Discussion Forum
Share your knowledge, ask questions and explore popular discussions about everything ACC
Proxy on viewer API breaks PDF viewing
0 REPLIES 0
Message 1 of 1
jan.gladines
46 Views, 0 Replies
We've implemented proxying the viewer requests to our own server to hide the access token. This is done as follows:
Options when calling Initializer
  const options = {
    env: 'AutodeskProduction',
    shouldInitializeAuth: false,
    endpoint: `${process.env.NEXT_PUBLIC_SITE_URL}/api/forge/viewer-proxy`,
    api: 'derivativeV2',
And then a simple Hono route, inspired by one shared here
import { Hono } from 'hono';
import { AppEnv } from '../../../app';
import { withConstantAutodeskToken } from '../authentication';
const HEADER_WHITELIST = [
  'if-modified-since',
  'if-none-match',
  'accept-encoding',
  'x-ads-acm-namespace',
  'x-ads-acm-check-groups',
export const viewerRouters = new Hono<AppEnv>().get(
  withConstantAutodeskToken,
  async (c) => {
    const tokenRes = await c.var.getConstantAutodeskToken();
    if (tokenRes.isErr()) {
      return c.json({
        error: tokenRes.error,
    const token = tokenRes.value;
    const proxyPath = c.req.path.replace(/^\/api\/forge\/viewer-proxy/g, '');
    const headers: Record<string, string> = {
      Authorization: `Bearer ${token}`,
    for (const header of HEADER_WHITELIST) {
      const headerVale = c.req.header(header);
      if (headerVale) {
        headers[header] = headerVale;
    const url = `https://developer.api.autodesk.com${proxyPath}`;
    return fetch(url, {
      headers,
      .then((resp) => resp.arrayBuffer())
      .then((buff) => c.body(buff))
      .catch((err) => {
        console.error('ERROR');
        return c.json({
          error: err,
This works great except for pdf files, there I get hit with `Logger.js:188 invalid file header signature`. I tried to figure out which header this would be, forwarding almost all headers for both the proxied request and the response but to no avail. Hopefully someone can help me with figuring out what's going on here! Thanks in advance!
Tags (2)
Labels (1)
0 REPLIES 0
View short, easy-to-follow videos about how to use Autodesk's construction products.
