ACC General Discussion Forum
Share your knowledge, ask questions and explore popular discussions about everything ACC
Project template missing the DOCS module
7 REPLIES 7
Message 1 of 8
abUXNMQ
551 Views, 7 Replies
I have created a new project template from scratch and the module DOCS is not showing/missing.
I have assigned product and permissions to members, both Docs and Build.
Where did I go wrong or is there something I have to activate in addition to the product and permissions?
I hope sombody can help me quickly with this issue.
Best Regards
Anne
Tags (1)
Labels (1)
  • Docs
7 REPLIES 7
Message 2 of 8
andr3sant0s
in reply to: abUXNMQ
Hi @abUXNMQ
I replicated your process and the same thing happened!
For the Project Admin activate all Product access and refresh the page. In my case it solved the problem. After that you can disable Product access for the products that you don't want.
Please use Accept as Solution and like/Give Kudos as appropriate to further enhance these forums.
Message 3 of 8
abUXNMQ
Thank you for the quick reply. I changed the setup as you suggested, but unfortunately it did not solve the problem on my part.
Do you have any other suggestions for problem solving?
BR Anne
Message 4 of 8
andr3sant0s
Did you refresh the page after activating all Product access?
It's seams like a bug to me, so no straightforward solution.
Message 5 of 8
abUXNMQ
Yes, and I tried it twice, just to make sure
Message 6 of 8
andr3sant0s
@abUXNMQ
Sometimes it takes some tries to get it to work.
I noticed that changing a member from project admin to project member can also help.
Has I said, this seems to be a bug and with no direct solution.
Message 7 of 8
abUXNMQ
Thank you so much for your help.
This solved my problem!
BR Anne
Message 8 of 8
caic.wds
Hi, I'm facing the same issue here. None of the solutions work for me. Has there been any news on this topic? several projects showing the same issue.
View short, easy-to-follow videos about how to use Autodesk's construction products.
