ACC General Discussion Forum
Share your knowledge, ask questions and explore popular discussions about everything ACC
Plant3d in ACC vs Plant3d in Vault
0 REPLIES 0
Message 1 of 1
stefan.sikora7MRAK
78 Views, 0 Replies
Hi there;
In the past we used Plant3D in an Environment with a non Autodesk PDM System.
The was synchronization between the server (MS-SQL-Instance) and client was handled by the PDM System itself.
Now that PDM System has been ditched and we want to go for a Autodesk only solution.
We already use Vault in conjunction with Inventor.
On the other hand, a subsidiary of us in the US is already setting up Plant3D in the ACC.
So now we have to make a decision which way to go.
The Cloud solution has the charme that user-rights administration is much easier, especially because we work with "outside" engineering partners that we have to give access to our data.
The downside is that you are not 100% in control of your own data because it is hosted by somebody else.
Questions: when setting up a Plant3D project it requires the setup of a MS-SQL Database on the server.
As a standalone as in Vault, a MS-SQL Database instance costs money.
Is the cost for that database instance covered by the license fees for the cloud-services or would Autodesk charge us for this separately ?
How do the cloud services handle backups ?
For instance, how to handle a broken Plant3D-dwg and maybe a according database rollback ?
thanks in advance
Labels (1)
0 REPLIES 0
View short, easy-to-follow videos about how to use Autodesk's construction products.
