ACC General Discussion Forum
Share your knowledge, ask questions and explore popular discussions about everything ACC
🔊 Introducing Content Catalog: The New BIM Management Tool for AECO
11 REPLIES 11
Message 1 of 12
handjonathan
1446 Views, 11 Replies
We are thrilled to announce the launch of Content Catalog, a cloud-based digital asset management tool designed to provide a single source of truth for storing, versioning, and accessing BIM content, including Revit families. Content Catalog is the new Autodesk integrated version of UNIFI Pro, available to Autodesk Docs subscribers at no additional cost.
With this launch, Content Catalog will only be available to those who store their data via the US data storage location. Access to Content Catalog, for those who utilize the EU and Australia storage locations, will be available at a future date.
Get started with Content Catalog today
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Labels (1)
11 REPLIES 11
Message 2 of 12
I look forward to checking this out!
Kristina Youngblut
Product Owner - BIMWorkshop
BIM Coordinator - CIMA+
25+ years Autodesk User
LinkedIn
Message 3 of 12
Cadguru42
in reply to: handjonathan
Does anyone know if this supports anything related to Civil 3D? The marketing links about this mention C3D, but I cannot find any information about how it can help or work with C3D.
C3D 2022-2025
Windows 11
32GB RAM
Message 4 of 12
orenco14
It appears this does not work for Revit Legend views at the moment, which would be the main use case of our firm (for typical details in all projects).
Also only a few sheets are showing up from any model, I'm not sure why.
Message 5 of 12
floretti
@handjonathan Would you know if there are any plans to release an API for the content catalog? At the moment that's probably what's holding our company back from using it as we have several custom tools that interact with the Revit libraries. Thank you.
Message 6 of 12
shaiGV878
Hi, I started to explore Content Catalog. I use type catalog but it seems that families with type catalog *txt* associated dont work. When I try to insert the family into a revit file I get the error "Unable to download type catalog".
On the Autodesk site it says that txt files are supported. So is it possible to use type catalog inside Content catalog?
Message 7 of 12
MichaelWolff
How do I get to display the actual content of an rfa file rather than just a blown up version of the thumbnail?
Message 8 of 12
We're having an issue with an .rvt file uploaded to Content Catalog, the file is shown as being processed for days, and it also shows as being Revit version 2009 although it's actually Revit 2022.
We've originally uploaded the same file with no issue and it was processed and was available in Revit versions 2022 to 2025. This problem started fter uploading a new version which had issues with being processed. We tried deleting it and re-uploading but the issue persists.
P.S. just to clarify, this is a .rvt file containing details which are copied across multiple projects, hence why we'd like to use Content Catalog as a solution for having the file available in all Revit versions easily.
Message 9 of 12
jstoddardH7RZD
in reply to: shaiGV878
Same issue here, trying to test out Content Catalog as a year ago we were ready to use UNIFI when it was actually working...
Message 10 of 12
@handjonathan, do you have any updates on .txt type catalogs not working within Content Catalog? Our firm was about to move on this, but it appears that certain features that windows explorer can handle aren't quite working yet..
Message 11 of 12
zharperCKJP9
in reply to: MichaelWolff
In my experience, it takes a while for the 3D preview of the .rfa file to appear. For the first couple hours, I can only see the thumbnail.
Message 12 of 12
jstoddardH7RZD
@shaiGV878 from the Architecture post
‎12-17-2024 12:44 PM
The part about the UTF-8 format was brought up by a different user earlier in this thread.  I cannot guarantee that will be the fix or not for you.  @bryanBYS ???  You have any helpful hints for jstoddard?
You should have 4.0.73, but you also have to make sure you've installed the version 1.1.2.3 of the extension.  The only way to figure out which version of that you have is to go into Add/Remove programs and look to see which version it says you have there.
If none of this helps, I would definitely go the ticket route.  They are attempting to get to those ASAP.  I know they are trying to clear their logs before the holiday break!""
Re: :speaker_high_volume: Introducing Content Catalog: The New BIM Management Tool for AECO - Page 3...
The UTF-8 formatting ~seemed~ to be my issue. I verified all of my type catalogs were updated/in this proper format & reuploaded them with their families (so they associate within Content Catalog) and it appeared to work correctly from there
View short, easy-to-follow videos about how to use Autodesk's construction products.
