How to manually push an update from source project to target project in ACC Bridge?
rakesh.borse
Community Manager Community Manager
rakesh.borse
I have bridged  a folder from source project to target project with auto sync off. I do not want to use auto-sync as I need control on my side when I can push changes to target. So how to manually push an update from source project to target project in ACC Bridge?
andr3sant0s
Hi @rakesh.borse
The bridge tool will only update when auto-sync is on.
If auto-sync is off bridge tool will send a static copy of the data and there isn't the option to resend the information again. You will have to create another outgoing package to the target project.
Please use Accept as Solution and like/Give Kudos as appropriate to further enhance these forums.
rakesh.borse
Thanks for the answer @andr3sant0s.
How about a scenario where I have set auto-sync ON but somehow auto-sync is not working and I want to push manually push update?
andr3sant0s
For that I have no solution...
One thing about auto-sync is that it only works when you share a folder, when you share a file auto-sync isn't available.
One other thing is that when you share a folder for the first time with auto-sync, the bridge tab and outgoing will show no in automation, this will change once you make any change to the outgoing folder.
rakesh.borse
Thanks for the explanation @andr3sant0s
hesham.bendary1
@andr3sant0s Hello dear,
How can I delete or void the outgoing or incoming rows in the ACC Bridge? Please note that I have already tried canceling the Bridge and deleting both the source and target folders, but the shared outgoing and incoming rows still remain visible in the ACC Bridge module.
curtisridenour
i posted this same question. i dont think it is possible to remove them. i dont think autodesk wants that to be part of the workflow.
https://forums.autodesk.com/t5/bim-360-support/autodesk-construction-cloud-bridge-outgoing-and-incom...
