How to limit information being shared to ACC
ARA_Rizky
Message 1 of 11
ARA_Rizky
Hi, I'm still new to ACC. I understand that ACC is designed to facilitate seamless information sharing among all project stakeholders, including clients, BIM managers, engineers, etc. I'm curious if there's a way to exclusively share 3D models without including the drawings. While this may seem counterproductive, there are situations where consultants may require this option for negotiating with clients
Thanks in advance
Replies (10)
Message 2 of 11
handjonathan
Hi @Anonymous_Rizky
Thanks a lot for posting your question to the forums!   I am linking in @Chad-Smith & @ChitnisPrateek, who maybe able to advise on the best workflow.
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Message 3 of 11
Ryan_Holland_LDP
Hi @ARA_Rizky
I would recommend placing your models into a separate folder within Files, and then giving permission to the Client to only this folder (view only access will be ok). If you need help with the permission settings this page on the help website should be useful DOCS Help | Folder Permissions | Autodesk.
Message 4 of 11
Chad-Smith
Further to @Ryan_Holland_LDP's reply, if that model is from Revit, then use the Revit Publish Settings to be specific about which drawings you want to include/exclude. But ultimately, folder permissions set to View Only is the best solution.
Select Views and Sheets to Publish to the Cloud
Message 5 of 11
ARA_Rizky
Hi Ryan,
Thank you for your reply. However, the issue is that our files are stored in the cloud, making it easy for the BIM management team or other consultants to download our Revit files and access the sheets/views within our model.
Is there a way to prevent this? Typically, in a 'non-live model', I would delete all the sheets/views from our model before sending it to the consultants.
Message 6 of 11
ARA_Rizky
Hi Chad,
This can be done, but I believe it would be pointless if they could download our Revit model and access views/sheets from it.
Message 7 of 11
Chad-Smith
Quick question.
Is the project in your account, or another company's?
You won't have total control if it's not in yours.
Message 8 of 11
ARA_Rizky
No. This project is managed by a BIM management company
Message 9 of 11
SietseKCS
Hello, I'm having a similar question.
We are sharing our Revit model with clients + third parties (stored on 3rd party server). Currently we are converting our production templates into revit (instead of autocad/excell), for a better internal workflow. However I do not want other parties being able to view our production drawings, or have access to the templates.
I know you can control what sheets/views get published, but as mentioned above, this is pointless if others can just download the revit model.
Perhaps we could create a dedicated production model, but as far as I know I’d still have to upload that to the ACC in order to link the live model.
Any ideas about this would be appreciated.
Message 10 of 11
RSomppi
IRC, when someone downloads the model, they get the latest published version. Change your publish settings to limit the "production drawings".
Message 11 of 11
SietseKCS
Hi RSomppi, thanks for the quikc reply.
That's actually a very good point, I did not realise. Still have the situation where others can still open our live model of course.
