ACC General Discussion Forum
Share your knowledge, ask questions and explore popular discussions about everything ACC
Bridge Automatically sync updates to target project is not available.
1 REPLY 1
glenncai
98 Views, 1 Reply
I'm new to ACC bridge. I would like to share a model with another project and have it automatically updated every time there are new changed published in the original model. However, the Automatic sync updates option is greyed out with message: "SHARING FILE WITH BRIDGE AUTOMATION IS CURRENTLY NOT SUPPORTED. PLEASE SELECT FOLDER INSTEAD" Anyone solution of this? Thank you!
Labels (1)
1 REPLY 1
Chad-Smith
in reply to: glenncai
No solution via ACC. As the message says, only folders are supported.
From memory, the Autodesk Replication Tool will support individual files.
View short, easy-to-follow videos about how to use Autodesk's construction products.
