ACC General Discussion Forum
Share your knowledge, ask questions and explore popular discussions about everything ACC
Automatically pull location boundaries from Revit rooms to Sheets
0 REPLIES 0
Message 1 of 1
sfedak
107 Views, 0 Replies
Currently, you can import rooms from a Revit model as locations in the project, which is great. However, you have to manually draw the location boundaries for each "location" on each sheet. This is very time consuming. It would be great if the ACC pulled the room boundaries right from the model and automatically applied them as locations in the project on every sheet in which that room is shown. This way, when you create issues, you can just click on a point in the room on any sheet and it knows what "location" your in.
Labels (2)
0 REPLIES 0
View short, easy-to-follow videos about how to use Autodesk's construction products.
