ACC General Discussion Forum
Share your knowledge, ask questions and explore popular discussions about everything ACC
Autodesk Takeoff - how do I change the height of a bunch of linear takeoffs at once?
1 REPLY 1
membrec
74 Views, 1 Reply
When using linear takeoffs to measure area (like for wall paint) I have to provide a value for height. I can set the default in the takeoff type definition, but what if that number changes? Or what if I forgot to provide a default?
I have found that I can change the values in the Inventory, but I can only do it one takeoff item at a time. Is there an easy way to bulk edit these properties?
Chico Membreno - Product Manager
Labels (1)
1 REPLY 1
membrec
in reply to: membrec
If you go into detailed takeoff, you can modify properties for multiple takeoff items at once. Detailed takeoff can be accessed via the more menu in the takeoff types panel (image 1) or by double clicking on the takeoff type name.
The left panel will switch to something that looks like image 2. You can select multiple rows by holding the Ctrl key while clicking, or by selecting the items in the viewer. Once selected, you change the value in the Inputs section and press the Tab key, or click elsewhere in the panel.
View short, easy-to-follow videos about how to use Autodesk's construction products.
