ACC General Discussion Forum
Share your knowledge, ask questions and explore popular discussions about everything ACC
Autodesk Construction Cloud Deleting Parameter Collections
4 REPLIES 4
loris.faiss
238 Views, 4 Replies
Hi
I was wondering if its possible to delete or archive existing Parameter Collections on Autodesk Construction Cloud?
I created a "test Collection" and it seems there is no way to remove the collection even tough its empty.
Thanks in Advance!
Kind Regards
4 REPLIES 4
Hi @loris.faiss please follow the link below, it talks about how you can archive parameters.
https://help.autodesk.com/view/DOCS/ENU/?guid=parameters#edit-parameter-collections
If this works for you, please mark this as a solution so its easier for other users to find. Thank you!
Symetri Logo
Prateek Chitnis
Strategic Implementation Manager | AECO (Buildings)
facebooktwitterInstagrampm
Hi, Thank you for the reply
I know how to archive single parameters, but my question is if i can archive a Parameter Collection.
For Example I create a new Parameter Collection called "Test_Parameters", where I add a few Parameters. Now my Test is over and i want to delete/archive the Collection "Test_Parameters" so it doesen't show up anymore. How can i do that?
Thanks again!
Kind regards
I have the same concern. There is no apparent tool available to archive a collection yet.
@ChitnisPrateek can you confirm this for us?
Chad-Smith
in reply to: loris.faiss
The Parameter Library is still in its infancy and is undergoing development. Especially around the ability to delete, archive, and restore (archived) items.
I would suggest adding your comment to this thread, which was created by and monitored by Autodesk as they seek feedback.
View short, easy-to-follow videos about how to use Autodesk's construction products.
