ACC General Discussion Forum
Share your knowledge, ask questions and explore popular discussions about everything ACC
ACC viewer - section analysis face selection
0 REPLIES 0
Message 1 of 1
ole.meyer-skjolingstad
78 Views, 0 Replies
Hi
My suggestion is to add Face Selection in section analysis in the ACC Viewer. Now you can only choose X- Y- or Z-plan, and then you need to rotate the section very rough by dragging the rotation arrows and try to align them as close as possible to the plane where you want to do a section cut. This is not an easy task to do.
This could easily be solved by being able to select a face to align the section plane, and then be able to drag the plane normal to the selected face to adjust to preferred section.
Tags (3)
Labels (2)
0 REPLIES 0
View short, easy-to-follow videos about how to use Autodesk's construction products.
