ACC - Issue - Project Naming - 2024
cadmanager
cadmanager
Hi
I resently discovered an issue when naming Projects in ACC Docs.
It may be in a post here somewhere, but couldnt find any 😊
I like to name and list my Projects and projectfiles, using the vertical bar(line | ).
  • Ex. (Number | Name | Adress | Ect.)
  • It makes it more professionel and many of our clients requires it.
We have now been having an issue when creating a new project in ACC and a Cloud Model from Revit 2024
(Maybe other versions aswell).
  • When trying to open the project, the loading window freezes and you have to shut it down in the "Task Manager".
  • I have tried many thing and finally found that when using the vertical bar in the name, it wont load.
  • If you change the name and remove the vertial bar, you have to download the project and resave it as a Cloud Model (Start over).
  • If you change the name and add the vertical bar, it will load, but when you save it and open again, it freezes.
Solution:
  • Autodesk should solve the issue 😁
  • Or just avoid using the vertical bar when naming your projects.
MirraLee
Hi
The | would be considered a special character and thus will not work.  Having a long project name c/w address is going to push the 255 limit.
ACC follows the Micsrosft rules for naming and characters. Do not exceed 255, and spaces count as 3 characters, and a typo of an space at the end of folder will also cuase problems.
https://learn.microsoft.com/en-us/rest/api/storageservices/naming-and-referencing-shares--directorie...
cadmanager
Hi
Know the MS rules on charactors, but they normally put down limits and warrings, so it dont reach the point where it get to be a problem.
At the moment you can start a new project, name it, with just one wrong charactor by mistake - upload your projectfiles, and then the project is already crooked and you have to start over.
Dont think its surpose to be like that and definately think there is a solution 🙂
