ACC General Discussion Forum
Share your knowledge, ask questions and explore popular discussions about everything ACC
ACC - Can Inventor files be saved to ACC?
3 REPLIES 3
MirraLee
198 Views, 3 Replies
Hi
I feel like I am missing something as I thought this was possible, but I do not see anything confirming this. I was under the assumption that Inventor, Revit, Navis, Acad, and C3D + more could all be hosted and viewed on ACC.
I just tested Inventor, and it will save a view to share, but this is hosted on Autodesk Cloud Viewer, not ACC.
Can these files, especially the exported dwg, be saved to ACC? Or will these need to be saved to the server or drive and manually uploaded to ACC?
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-DFAE9DFD-6300-47D3-AF97-C389B70F6414
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=Inventor_ReleaseNotes_release_notes_html
When opening a file, the Autodesk Docs icon for the cloud server is not visible, and yes, I have Collaborate Pro and see this with C3D.
Is there a tool needed?
3 REPLIES 3
dbutts7
in reply to: MirraLee
Autodesk has currently stated through the Desktop Connector documentation that Inventor is not supported, but I've cheated a little and saved/added files through the Autodesk Docs shortcut. Bringing in and saving external parts into or for an assembly may be problematic right now - but for our use (converting manufacturing content to Revit families) it works for that part.
https://help.autodesk.com/view/CONNECT/ENU/?guid=Historical_Releases_Desktop_Connector
thanks - db
David A. Butts
Engineering Technology Manager - Gannett Fleming
Revit Certified Professional/Autodesk Certified Instructor
Revit, AutoCAD Architecture, MEP, Plant 3D, BIM Collaborate Pro Subject Matter Expert
The MEP BIM/CAD Engineer Blog
dbutts7
One quick note - I'm not editing the files there, I'm downloading local for now then uploading results back.
David A. Butts
dbutts7
in reply to: dbutts7
@MirraLee I did some additional tests - the iLogic files caused an issue when attempting to save directly to an Autodesk Docs folder. This included the Rules folder that gets generated. We're doing some additional testing to see if the manual copy works with models that include iLogic, will try to post our results later.
thanks - David B.
David A. Butts
View short, easy-to-follow videos about how to use Autodesk's construction products.
