ACC BUILD Reference Specifications on Sheets
geoffrJ2LUC
Message 1 of 1
geoffrJ2LUC
With the newly added (March 2024) Specifications tool in ACC Build will Autodesk make you able to reference the specification Code or Description from a sheet?  It seems to be one of the only tools that you're not available to reference.  For example, in a residential project, we have light fixture tags labelled as LT11, LT12 etc. and a Spec page for those lights with Specification Codes that matches the light tags, ex. LT11, LT12 etc.  If the OCR in sheets doesn't reference these spec codes,  will Autodesk eventually make it possible to manually add a reference on a sheet similar to drawing references?
Replies (0)
