ACC General Discussion Forum
Share your knowledge, ask questions and explore popular discussions about everything ACC
jamizu
569 Views, 2 Replies
ACC Bridge
Hi, forum team
I have a doubt about ACC bridge tool: in a shared situation from "ACC project1" to "ACC project2" (different owner account); does the files will be available for the 2 projects forever or only while the ACC1 project 1 exists?
<thank you
Tags (1)
2 REPLIES 2
gareth.spencer1
in reply to: jamizu
Hi @jamizu,
The files should remain in both projects unless a project admin or member with the correct permissions can move them to the deleted items area. If someone deletes the bridge link then the files will not transfer over automatically.
Please click the Accept Solution button if my reply answers your question.
Twitter: @TheDarkAsset
LinkedIn: gareth-spencer-84202532
Gareth Spencer
BIM Technical Consultant | Man and Machine (UK)
Trent_Field
in reply to: jamizu
Just another note on this, if you remove a file or rename it in your project and this folder is synced, the receiving project will not delete the file, however it will receive a version 1 of the renamed file. Keep this in mind if you ever rename or delete files.
View short, easy-to-follow videos about how to use Autodesk's construction products.
