Hello everyone,
This tip is around using the print feature inside of Team. There are a couple things that help make the process a little smoother.
To see the print option, open up your drawing. You will see the Print button in the toolbar along the bottom of the viewer.
Once you click on the button, you will see what looks like a sheet of paper. Move that around to get the orientation you want for your print. Note that you have a toolbar that lets you manipulate the model based on the type of drawing you have open in the viewer.
Once you have the paper positioned where you want it, click on your mouse or trackpad button to select that view. You will see a camera icon, updated text in the lower right corner letting you know you have a view to print. You will see the option to "Cancle" and "Print" on the lower right corner.
Note that you can create multiple screen shots for printing, then print them all at once, or just click print for one sheet. In this case, I am printing from Windows 10 and have the option to change my printer to PDF. You can also select your system printer and print that for an actual hard copy.
Take it for a spin and see what you think.
Happy Printing from Team.
