Hello A360 members,
Here is a quick tip on how to enable Project Contributors in a project.
From A360 go to the Project.
Click on the gear icon in the upper right hand corner of the project.
Now click on the Gear Icon to see the Project Settings.
TIP: You can also change the type of project here.
Now slide the button until it turns green and enables "Allow Project Contributors"
Save your settings and you have now enabled Project Contributors in your Project.
Hope this helps with this quick tip on how to enable Project Contributors in A360 Team.
Thanks Jason,
are res you able to see I've icon in any other project? Also is this a Team Hb, or a single project free hub? F that's the case, you won't be able to see he project settings.m
thanks and and let me know if that's the case.
Hi Jason,
thanks for for the update. If you don't see the gear op icon, then you have the free personal hub. Can you share with us why you are trying to Chang the project type?
Also if you look under your profile icon in the upper right hand corner, you will see a list of hubs you are a part of.
Hope this help.
I'm in the same boat as Jason, no gear icon. I assume my A360 account is set to the free personal hub. How do I get access to the team hub? I'm the administrator of autodesk subscription for our company, but haven't seen any emails concerning how to take advantage of these new features. I'm having to do all the discovery, like what I see and would like to experiment, please advise.
Hi Seth,
Yes, if you have a Free Personal hub, you'll want to create a 30 day free trial to see the Gear for editing project type in the above as a first step.
So, to start with A360 Team, go to (a360.autodesk.com) where you'll be able to
A couple of links that I typically recommend right to start with are the below, (that are right here in the Tips and Tricks forum page), so please let us know if you have further questions after you get started.
Have a great day ![]()
Thanks for the guidance and links. I'm looking through those resources now... ![]()
Sounds great Seth,
Keep us posted on your progress, and have a great day ![]()
