Including mass material in takeoff schedules
I found out that masse's materials are not included at the time of generating a material takeoff schedule. It would be nice if you could include this, because you could schedule the exact amount of earth extraction by modeling masses. By doing this, you should be able to calculate how many trucks you would need in a suposed scenario or even to obtain precise amounts to calculate your costs in a construction site.
I hope this info turns useful.
Nicolas
1 Comment
JvHardeveld
Nicolas,
I think you placed this in the wrong section of the forums of autodesk.
This is the A360 Rendering part of the forum.
But to your question, you can use your building pad for this problem,
Use your building pad with the pick lines function or draw a boundary around your mass and after that your exact amount of earth will be visible.
I hope it will help.
Kind Regards,
Job van Hardeveld
Cadac Group
