Some Revit users reported that material texture is scaled in cloud Rendering when using Revit 2014 RTM version.
Solved by adayan_adsk. Go to Solution.
Please update Revit to 2014 UR2 to solve this problem. You can find appropriate update links from the following:
http://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/revit-structur...
http://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/revit-architec...
http://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/revit-mep-2014...
http://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/revit-2014-upd...
http://knowledge.autodesk.com/support/revit-lt/downloads/caas/downloads/content/revit-lt-2014-update...
