Hello everyone,
I'm using Revit 2015 and I'm not able to use the tool "Render in cloud": during the step 1 the message " Unable to get Cloud Credit balance" appears. I knew that credits for student license were unlimited... is something changed ? It's strange because I've already used this tool in the past and it worked perfectly.
Thank you for the help.
Solved by SallyDong2005. Go to Solution.
You are right, students have unlimited cloud credits. Have you registered as a student at student here: http://students.autodesk.com/
After you register, be sure to download Revit (even if you have it already). This will associate your Autodesk ID with a student subscription.
Thanks.
Thank you very much for your answer,
unfortunately I've tried to reinstall the product from the linked page but the cloud doesn't work yet. Is there something else that I could do to solve the problem ?
Thank you again for your disponibility.
Hello Edoardo,
From the error message, the problem seems not related to your account, it may be caused by that your network cannot connect to credits count service or the credits count service's instability. Could you share me the screenshot of the error dialog you saw to let me check it? And could let me know if it have been worked well before on your this machine?
I've added the screenshot as asked. I've used rendering in cloud before on this machine with no problems, but Revit version was different. I used Revit 2013.
Thank you.
Hello Edoardo,
Could you try this work around to check wheter it can work for you.
1. Press WIN + R key to open Run window.
2. Paste %localappdata% to the input box and click OK.
3. It will open a file explorer and show the path like "C:\Users\USERID\AppData\Local\Autodesk"
4. Find "Web Services" folder and rename it to anyother name.
5. Close your Revit and relaunch it.
6. log-in agian and try cloud rendering again.
Any problem please let me know.
Goodmorning,
I've tried to do as suggested but the problem still remains...
Thank you anyway.
Could you try to install a web debug tool to hlep to debug this problem?
1. install fiddler from here: http://www.telerik.com/fiddler
2. lanuch fiddler
3. lanuch Revit and click render in cloud
4. go back to fiddler and click File-> Save -> All sessions...
5. send the saved file to me (yuejuan.dong@autodesk.com)
Thanks in advanced for working with us on this problem.
Through the communication by email, we finally found the root cause was the customer's IE browser blocked cookies. He resolved this problem by decreaseing the settings against cookies.
Post the detail steps for others:
I am facing the same problem. But neither of the solutions helped me. What else can be done ?
We checked your account and it looks good from our data base. Could you let me know what's the error message you had seen to help to understand the problem clearly?
I have the same issue,I have the edu. linces but I dont have any credit,whaen I go to account management it said that I have a student accsess to the cloud rendering.Please help me with that,I will be so appreciated
It's work yestreday,and today its back to 0 credit,how I can fix it again?
