when I render in the cloud reflections appear black
I've attached the clud render and a pc render (draft) the pc render is how the reflections should appear
Hello @jasonmazis,
I checked your rendering history, and it looks good in your later cloud rendering result. It this still a problem please let me know.
Hi Sally
Thanks for getting back to me. I had originally created the mirror from an aluminium with 100% reflections and it worked on my home pc, but not on the cloud.
As a result i deleted the window and downloaded a mirror from a forum which worked perfectly. The aluminium however still would not show reflections if i render any item with that material on the cloud.
Hi @jasonmazis,
Could you share me a test file of the problematical aluminium material? support.autodesk360.rendering@autodesk.com.
Hi @jasonmazis,
Have you tried render the view in Revit to check whether it could give you correct result? If Revit can render it correct, could you share your Revit model to let us check it?
