Rendering Forum (Read Only)
Welcome to Autodesk’s Rendering Forums. Share your knowledge, ask questions, and explore popular Rendering topics.
Online Rendering Revit 2017
14 REPLIES 14
Message 1 of 15
qayyum2
569 Views, 14 Replies
I have recently upgraded Revit 2016 to Revit 2017 and the models that I could easily render through online rendering do not work under 2017.
The moment I accept the online rendering settings under 'Render in Cloud' (irrespective of the type of resolution) Revit crashes and leaves the following message:
I have tried three different models, ranging from complicated to a simple model with just two spaces, on Revit 2016 & Revit 2017 on the same machine. All three models presented results from online rendering in Revit 2016 but none from Revit 2017.
Any possible reason??
qayyum2
14 REPLIES 14
Message 2 of 15
SallyDong2005
in reply to: qayyum2
Hi @qayyum2,
Could you install a web debug tool to debug this problem?
Steps:
1. install fiddler from here: http://www.telerik.com/fiddler
2. launch fiddler and then launch Revit 2017
3. open a project file in Revit 2017 and then try cloud rendering
4. once the error dialog pop, go to fiddler File--> save --> all sessions
5. send the saved file to yuejuan.dong@autodesk.com
Sally Dong
Message 3 of 15
qayyum2
in reply to: SallyDong2005
Hi Sally,
Followed your steps to install, run and save file from debug tool...
Did you receive file sent from 'Fiddler' sent to yuejuan.dong@autodesk.com?
If yes, did you find any issues with the system or program installation?
qayyum2
Message 4 of 15
SallyDong2005
Hello @qayyum2,
I did not received your email. Could you resend it? Thanks in advanced.
Sally Dong
Message 5 of 15
qayyum2
Hi SallyDong2005,
See attached error file from Revit 2017 cloud rendering failed attempt.
Hope it helps you identify the culprit...
Good luck.
Pl confirm receipt of zip file.
FQN
Q2 on S4...
Message 6 of 15
SallyDong2005
Hello @qayyum2,
Do you attached the zip in your post or send me by email? I have seen any email currently. could you attached here?
Sally Dong
Message 7 of 15
qayyum2
Hi SallyDong2005,
See attached file 'Error_060217' containing information that might help you shed some light & possibly find a solution for the situation I am in.
It is interesting to note that on the same machine, with the same model under the same user name I have no problem doing the online rendering in Revit 2016.
Thanks for your support.
Farhat Qayyum Naz
Teacher | Architectural Technology Section
T +61 2 96829645 | M
E farhat.qayyumnaz@tafensw.edu.au
TAFE NSW
Room KR120, Block 'K'
136 William St Granville NSW 2142
www.tafensw.edu.au
[jpgs/TAFE_email5.jpg]
This message is intended for the addressee named and may contain
privileged information or confidential information or both. If you
are not the intended recipient please delete it and notify the sender.
Message 8 of 15
qayyum2
Hi SallyDong2005,
Farhat Qayyum Naz
TAFE NSW
www.tafensw.edu.au
Message 9 of 15
SallyDong2005
attachement.pngHi @qayyum2,
I cannot find any attachment in your post. Could you make sure you attached the attachment correctly?
Sally Dong
Message 10 of 15
qayyum2
Hi SallyDong2005,
Finally attached the file by following your recent screenshot.
Previous two attempts were made by attaching the file to email responses.
Hope this information helps to identify the problem and possibly find a solution.
Thanks a lot for your help & support.
qayyum2
Message 11 of 15
SallyDong2005
Hi @qayyum2,
We cannot get the https traffic from your attainment, Please enable Fiddler to decrypt https traffic, and then the log file could be more useful.
Steps:
  1. Launch Fiddler and go to Tools -->  Telerik Fiddler Options --> Https tab --> check the option Decrypt https traffic
  2. Launch Revit, and try cloud rendering.
  3. Once the error dialog pops, go to fiddler File --> Save --> all sessions and then send the file to me.
Sally Dong
Message 12 of 15
qayyum2
Hi Sally,
See attached file produced by Fiddler after following your instructions.
qayyum2
Message 13 of 15
qayyum2
Hi Sally,
The issue I raised a few weeks ago regarding Revit 2017 crashing on sending a model of any size, shape or complexity for online rendering.
I believe that I have found a fix for the problem and successfully tried/sent a number of models to Rendering360 before typing this message.
The culprit was NBS plug-in for Revit 2017 by nbs.com. I uninstalled the plug-in, restarted the computer and Revit 2017 stopped crashing immediately after making contact with Rendering360 site.
Right from the start of this issue I believed that there was something not right between Revit 2017 & the plug-ins that I added on to the software. I did get rid of most of the add-ons but did not pay attention to the NBS plug-in till today.
It is interesting to note that the same plug-in works fine with Revit 2015 & Revit 2016 on my machine. I m not sure why this particular plug-in does not go with Revit 2017, but I would love to find out whether there is something wrong with the plug-in or it was not installed properly, or it had conflict with something else on my computer.
Has anyone else complained of a similar mismatch between Revit 2017 & NBS or any other plug-in?
I really want to thank you & everyone at Autodesk help located in Singapore, in particular Yuri Kim, who spent almost an hour with me using remote access to try to find a solution. Although that session did not eventuate in identifying the problem, but it definitely showed me a number of possible ways to look at the problem.
One more time thanks for your help, support and such a high level of customer service.
Best Regards,
Farhat Qayyum Naz
Message 14 of 15
SallyDong2005
Hi @qayyum2,
I am glad to know the problem has been resolved and thanks for you let us known the solution, it will be very helpful for others who encountered the same problem. Thanks a lot.
Sally Dong
Message 15 of 15
david.morris
Hi Sally,
NBS have recently become aware of this thread. We have tested the NBS plugin with Autodesk Revit 2017 and we can successfully render in the cloud.
We wonder if it could be an installation issue and hope you will continue to use the NBS plug-in. You can download the latest version of the NBS plugin from the Autodesk App Store or https://www.nationalbimlibrary.com/.
If you have any further issues with the NBS Plug-in please get in touch with our support team via support@thenbs.com.
David Morris
Customer Support Manager
NBS
