some Revit 2014 users reported that the models were not rendered in the correct plan when they use cloud rendering.
Solved by adayan_adsk. Go to Solution.
This issue has been fixed in Revit 2014 UR2 and later version, so please update Revit to 2014 UR2 via one of the following links.
http://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/revit-structur...
http://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/revit-architec...
http://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/revit-mep-2014...
http://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/revit-2014-upd...
http://knowledge.autodesk.com/support/revit-lt/downloads/caas/downloads/content/revit-lt-2014-update...
