If i want to rerender using environment based lighting i can only choose between a few. They are not sufficient because the have obstacles like trees buildings etc. They look imho terrible on the renderings.
I know you can use pictures as background in the render view but they are not rendered online?
Is it possible to create new environment pictures (360) based on my own created pictures?
Solved by anavaidya. Go to Solution.
Hi @hve-architecten,
We have heard this from other customers too. Currently the set of environments that we have are limited. We are planning on 2 things
- Add the ability to upload own 360 environments
- Add the ability to rotate environments, so that it fits your site & camera
Regarding using pictures as background, that can be done if you choose an image in background settings.
- Click on Render
- Go to Background -> Style -> choose Image and input a background image
Now when you Render in Cloud, that image will be used in the background.
